jimusbobus
I want to build a 2500 with this motherboard, are you likely to get this in stock? or can I send in the motherboard?
None of us work for PCS, and they don’t monitor the forums, you’d need to ask them.I want to build a 2500 with this motherboard, are you likely to get this in stock? or can I send in the motherboard?
apologies, i misunderstood the scope of the forum! tyvm for you reply ind info!!None of us work for PCS, and they don’t monitor the forums, you’d need to ask them.
You can’t send in a motherboard as PCS have no way of knowing it’s not been tampered with so can’t apply their own warranty
There is almost no scenario where an Intel build makes any sense anyway
Intel CPU's crashing in games
So there's been a lot of upset gathering steam on the inter webs with intermittent games crashes on Intel 13th and 14th gen. Workarounds range from underclocking to disabling ecores. BUT, there are a lot of people finding that simply disabling hyperthreading is a proper solution. The findings...www.pcspecialist.co.uk
