Lu-minaire
I’m having a major issue with my pc and am quite out of my depth. It’s basically unusable and I’m not even sure why. I shut my pc down normally on Thursday night then found it was already on when I went to turn it on Friday morning. On login, within 2 seconds, the desktop just starts constantly refreshing. Task manager will open and it shows various processes constantly loading and disappearing in a loop (search, windows explorer to name a few). My taskbar doesn’t ever load up, there’s just nothing there.
I have tried:
🔹 SFC /scan now (says it repaired some files, but after reboot there’s no difference upon login afterwards.)
🔹 Startup Repair (which said it couldn’t repair my pc)
🔹 System Restore (says it failed to restore and for some reason the only restore point was from the night before the issue began and the issue remains)
🔹 Uninstall updates (in case it had tried to update on shutdown) Quality update uninstall worked but feature update uninstall failed. Still no difference.
Loading into safe mode actually makes the desktop reload every 1 second instead of every 2 seconds.
🔹 Someone from another forum suggested running BOOTREC but that came up with the message “not recognised as an internal or external command, operable program or batch file”)
Any idea why this whole fault is happening? Or anything else I can try? Do I need to go the drastic step of Reset this PC? Or am I barking up the wrong tree and this is a fault outwith windows files? (Like hardware or driver conflicts) I have backed up important information this week, thankfully, but could still lose some data.
Any help would be majorly appreciated. Many thanks in advance (and please be kind 🙃 I’m not the most tech savvy these days).
Specs below for info.
(I also have Norton 360 installed.)
Promotional Item
Get Marvel's Midnight Suns with select GeForce RTX 30 Series GPUs!
ASUS® ROG STRIX B550-F GAMING WIFI II (AM4, DDR4, PCIe 4.0, Wi-Fi 6E)
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
512GB PCS PCIe M.2 SSD (3300 MB/R, 2200 MB/W)
8TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
External DVD/BLU-RAY Drive
6x Slim USB 2.0 External Blu-Ray Writer
PCS FrostFlow 100 V3 Series High Performance CPU Cooler (AMD)
2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Microsoft® Office Home & Student 2021 (1 Digital License)
Firefox™
I have tried:
Promotional Item
Firefox™
