First Gaming Build
bakat98
PCS SPECTRUM RGB MID TOWER CASE
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
8GB AMD RADEON™ RX 580 - HDMI, DP - DX® 12
256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
STANDARD AMD CPU COOLER
Firefox™
Price: £1,026.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/VsGJYPuEf3/
The price is already at my budget, so I wouldnt really be able to look at anything more expensive. I have not chosen a monitor yet but I would be looking to have 2 1080p 60fps monitors. Please let me know if giving any more information would allow you guys to help me more.
I was not sure about the storage situation. Is it necessary to have the SSD as M.2, or can I just have the SSD and HDD in the normal storage slots?
Thanks.
JUNI0R
Firefox™
Thanks.
Hi there! In todays market getting a gaming PC for £1,000 is very tight with high demand and low supply, prices have shot up. Although, it looks like you've been able to get a fairly decent one built here. If you're able to wait, I'd recommend doing so. Hopefully in the next few months, prices will come down so you'll be able to get more for your money.
For your budget, I'd recommend changing to the TUF B550 motherboard with WiFi as it's a better board than the Prime and the wifi is the same as the AX200 wireless card, for a few £ less. Also, the 1660 Super, is a better Graphics Card than the RX580 and currently costs about £20 less as seen in this video.
I think my primary concerns about this build are the Small SSD and the PSU. For the M.2 SSD, they're 100% worth it, they will give you significantly faster loading times for Windows over a conventional SSD and only cost a few £ more. But, that said, 256GB is very small if you'd like to put any games on there. The 512GB SSD although more expensive would allow for more space for games. For the PSU, if you plan to upgrade this system over time, you'll want to go for a minimum of the 750W TXm unit. The 750TXm may seem overkill now but the higher wattage will allow your system to run more comfortably and allow for upgrades down the read without having to change it. The 750TXm is the lowest I'd recommend although ideally I'd go for an RM or RMx 850W model.
A great way to save some money if you already have a PC or laptop that won't be used after this arrives is by removing the Windows license from the build and moving your current key across to this new build. It's a fairly straightforward process these days and will save about £85.
Monitors wise, 1080p 60hz is dying out realistically, the minimum I'd recommend for a new build is 1080p 144hz. The 1660 Super is a good card for this and with a tweak of some settings you should be able to get that comfortably. I'm not sure what you were planning to spend on the two monitors but a 1 better monitor setup might be the way to go for now. the MSI Optix G241 and AOC 24G2U monitors are both around the £200 mark and are popular recommendations on the forum. Then down the line you could either upgrade your monitor when you get a new GPU and that monitor will become a secondary one, or after buying this PC you could save up for a basic 1080p 60hz monitor to go along side it.
bakat98
Thank you for your reply and your input. I have made some adjustments per your suggestions. I dont't have a computer or laptop at the moment, so I would really like to get one ordered asap. I will be mainly using the PC for games. I very much like the look of the two monitors you linked to and would probably use one of them as part of the setup for the PC. I have listed my alterations below, please let me know if there are any issues that may arise (e.g case - unfortunately there don't seem to be many great options)
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Price: £1,089.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/37fGbsC5GK/
JUNI0R
This looks great! For cases, the TD500 mesh is a very nice case, but it is also quite expensive considering your budget. The Lian Li 215 is a fantastic case for the money and will provide all the cooling you’ll need. If you’re happy to swap to it, that’ll save a few £ that I’d recommend investing back into the PSU. I’ve gone for the 850RM which is £6 more expensive that your current config and well worth it. If you’re super tight on your budget, you can step down to the TXm750 which will come in at £4 under your new build assuming you keep the 215 case.
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Price: £1,094.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/NYYnrUAmme/
