Future proof wow spec
Once2014
Hi!
Is this a good future proof spec to play wow on max setting on a 1440p monitor. At the best frame rate and if not why and what other alternatives would you suggest bearing in mind my budget is 2k which this spec basically meets cost wise and also any idea why today when I was being impulsive and I tried to buy this pc but whenever I tried to pay deposit and have the buy now pay later option it would just kick me out and not let me proceed any further with the purchase ?
Thx
Hi!
Thx
A laptop is very different to a desktop for 2 reasons
1/. Can’t upgrade the gpu. In any computer the first bottleneck will be the GPU no matter what you fit. On a laptop, you can’t replace it, so for longevity you fit the highest tier you can afford.
2/. Laptop gpus are different silicon to desktops and quite a lot less powerful. So a desktop 4070 which would be ideal for mid level 1440p would equal around a laptop 4080.
Be aware also that the performance you get now isn’t what you’ll get in a few years. Games update all the time, WoW has already been through 2 graphics engine rewrites and that will continue, plus as DLCs are released using newer technologies, the required specs increase
You’ve pasted the configurator link rather than the specs, if you proceed on the specs, then select paste to forum we can see what you’re referencing.
Once2014
This is the spec!
Also any idea about the last question about trying to order online but it now proceeding past the deposit
Apologies, no idea why I thought it was a laptop!
If you could paste the specs as in the guide otherwise we can't make any amendments?
Once2014
Not sure why it’s not allowing be to. I copy to clip board and even when I pasted the link at the bottom it still didn’t work properly
Promotional Item
16GB AMD RADEON™ RX 7900 GRE - HDMI, DP - DX® 12
Graphics Card Support Bracket
2TB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 6500MB/sW)
CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/jfb3Kv5W7H/
Promotional Item
Microsoft® Edge
Site does seem to be a bit buggy today, I wonder if they’re doing some kind of updates.
It’s a very solid start.
The only suggestions I’d make would be to upgrade the PSU to the 1200w Shift model to allow for any upgrades in the future. “Transient spikes” are an issue with modern gpus since Ray Tracing technology hit that often isn’t accounted for
The 1200w doesn’t mean the system will draw 1200w, only that you have that headroom available. The shift model is also the new ATX 3 standard which is far more efficient and you’ll hardly ever hear it, I’ve got one and it’s quite incredible.
And then regarding your drives, best practice is to have a small one for the OS and programs, say 512Gb and then a dedicated one for your games, a P41 would be ample if you want to reduce costs, personally I’d suggest 2tb min these days as games are becoming over 100Gb nowadays quite frequently.
What Hz is your monitor btw? If you’re unsure what make and model?
Once2014
Monitor - 27 Inch WQHD (2560 x 1440), IPS, 155Hz*, ELMB Sync, G-SYNC Compatible, Adaptive-sync, 1 ms (MPRT), HDR10, Black​
Recently purchased!
I was gonna just get a single drive and risk it tbf! With the one above? I’m only playing world of Warcraft on max settings? Would this be a problem with the one drive ? I get if it goes wrong you lose everthing but my last pc had both the os and the game on and it was much smaller.
With the 1200? What would you suggest from the drop down menu ?
I wouldn't personally, you're gonna have to reinstall windows weather you like it or not, with a single drive you have to reinstall your games and everything which is totally unnecessary with a proper drive setup.
It's up to you, but there's no benefit to having a single drive on todays systems, it only reduces performance and ease of use.
If you've only got WoW, then perhaps a 512Gb OS and 1Tb Game drive, and it will be cheaper also than a single 2TB
There is only one
So the above photos maybe over powered but should be good choice ?
Apologies, I missed the cooler, you can reduce that to the H100 variant of your choice, no need for the 280mm rad on that cpu, it's crazy efficient.
The rest looks good though.
Regarding WoW, it's due for a graphics engine update, and I seriously think they may incorporate Ray Tracing as there's been a few mods that have implemented it successfully and it's so easy these days and makes such a huge difference, so expect GPU requirements to change in the next few years.
Once2014
So is there a gpu on the market atm you would suggest to avoid needing another upgrade in next few years ? I want to have a pc now I can just use and not worry. Also I may not end up even playing with ray tracing on but incase I do is there something instead of what I have you would change too?
You can't avoid upgrading, it's not possible. Games evolve constantly, there's nothing you can do to prevent your GPU becoming outdated.
All you do by buying an overspecced GPU now in the hope that it may be powerful enough in the future is pay a massive premium for outdated technology by the time it's useful and gives you poor performance compared to just upgrading to a current GPU at that time.
As you step up GPU tier, the price differential increases massively.
You always fit the GPU to the monitor, then upgrade when required.
Once2014
Hi there! I need some guidance.
Unfortunately, when testing the PC, we encountered a RAM stability problem. We have tested various components, changed configurations, CPU, and motherboard and found the solution is to change the RAM to a non-RGB version. We therefore recommend that you amend your your order. “
2nd M.2 SSD Drive
DVD/BLU-RAY Drive
NOT REQUIRED
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
Any suggestions as to what to amend the order to ?
Simply change the 32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) to 32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB)
But they must use lots of that RAM with that motherboard (as it's a config we recommend all the time), so they need to investigate why it's now an issue.
Once2014
Why would removing the rgb from it make it any better ?
I’m trying to understand if I would have been better off with another mother board or it’s as you said some new issue that’s risen with the config itself.
Only PCS and Corsair can say what's technically different between the 2 sets of RAM (it might be timing, batch, binning, or just the extra power draw of the RGB). It's very strange though.
It could be a completely random incompatibility between that batch of RAM and that batch of motherboards, as (as said previously) we've seen many with that config working perfectly over many months (of course there is the well-known issues of Asus boards not liking high speed RAM at more than 32GB, but that's not your case).
The 2 easiest options are lower speed RGB RAM, or non-RGB RAM...and they're both easy to test quickly.
Another motherboard is a major swap and more costly to you (£90 more for the Tuf X670)...but if you must have RGB RAM (I had to have it too, but on a Strix X670E motherboard) then it's either try the lower speed RAM or change the motherboard.
