Gaming Laptop £1.3k
Hello guys
Looking to buy a new Gaming Laptop to replace my old Proteus .
Whats the best bang for buck Laptop I can get for £1.3k? Just for Gaming and general usage. I play all sorts of Games so looking for an allrounder
Many thanks
D
Deleted member 17413
Guest
Does it need to be a laptop?
Prices are all up right now, and I think all the laptops PCS currently have are Intel only...it makes things difficult right now especially given the budget.
When you say all sorts of games, can you give some examples of the regular titles you play?
You could consider this (dead on your budget). Its very similar to my set up, but a little cheaper than I paid, but please note:
i) its only a 2060 RTX - whereas everything is moving on to 3000 series GPUs.
ii) I have included Gold warranty - you could lower this, but I always try to recommend it if it fits with budget as it is 2 years parts warranty for only £69 more.
iii) my laptop has been absolutely perfect and I've loved it as a gaming laptop, APART from the keyboard keys were wearing out / disappearing / scratching off. Its off being fixed and hopefully just a minor faulty part and new keyboard is ok but I have to wait and see.
iv) it is AMD and there are newer versions of AMD chips apparently due soon so if you can save a bit more and get extra budget you could risk waiting however again, prices are going up a bit PLUS you might miss out on this if you wait too long
Obviously you can swap around some of the drives or memory - ie increase the speed of memory if its available, decrease to 16Gb (2x8) if you want etc have a little fiddle around to see what you get and price changes. As @sibun1 mentions though, you will probably get more for your buck if you go desktop...but have you got a monitor?
Chassis & Display
Optimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen™ 7 Eight Core Processor 4800H (2.9GHz, 4.2GHz Turbo)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
Integrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor
1 x 180W AC Adaptor
Battery
Optimus Series Integrated 46WH Lithium Ion Battery
1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard Language
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
Chassis
TongFang GK7NR0R (6GB RTX-2060, R7-4800H, 144Hz, Blank KB)
Standard Build - Approximately 14 to 16 working days
Price: £1,300.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/optimusXI-pro-17/2sS9SZWjgU/
D
Deleted member 41971
Guest
also the nova is in stock, if it fits your budget
Cheers - I hadnt noticed that.
Another suggestion for you here - upping to the 2070 too and only just slightly over budget.
Chassis & Display
Nova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
16GB Corsair 2400MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Battery
Nova Series Detachable 4 Cell Lithium Ion Battery
2 Channel High Def. Audio + SoundBlaster™ Cinema
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
Keyboard Language
15" NOVA SERIES UK KEYBOARD
Keyboard & Mouse
Webcam
Chassis
Clevo NH55AFW (8GB RTX-2070, 144Hz N7, Blank KB)
Price: £1,339.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/nova-15/0kgXbfj8R2/
£1,335.00
This includes some extra optionals like a cooling stand. You could also swap out the SSDs with smaller ones or ones of a different brand to lower the price a bit.
Chassis & Display
Elimina Pro Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
16GB Corsair 2933MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
[500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)]
AC Adaptor
1 x 180W AC Adaptor
Battery
Elimina Pro Series Integrated 62WH Lithium Ion Battery
Keyboard Language
ELIMINA PRO SERIES RGB BACKLIT UK KEYBOARD
Firefox™
Laptop Cooling Stands
CoolerMaster NotePal L2 Laptop Cooler, up to 17.3 inch
Keyboard & Mouse
Webcam
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/elimina-pro-17/ngRBkCSCj0/
