Just over £1000 for this build, Thoughts?
Worth?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 2 100.0%
  • Total voters
    2
Jamc
Hi guys, I've had the same gaming PC now for a couple years and its due an upgrade, I'm not too clued in on parts that've came out in the last few years and thought id ask if this is a good build for mainly gaming, although I do use it for university work and CAD modelling but mostly on the side, please let me know if there are any parts I should sub in/out, thanks in advance.
I run dual monitors with the main one being a LC27RG50 240Hz Samsung monitor and the other is a BenQ GL2480 60Hz Monitor
I would say my max budget is around the £1400 mark if theres anything important needing to be added
Any help is appreciated
CORSAIR 3000D AIRFLOW MID TOWER GAMING CASE
Intel® Core™ i7 12-Core Processor i7-12700 (Up to 4.9GHz) 25MB Cache
GIGABYTE B660M DS3H DDR4 (rev. 1.0) : LGA1700, DDR4, USB 3.2
32GB PCS PRO DDR4 3200MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 4060 - HDMI, DP, LHR
Graphics Card Support Bracket
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
CORSAIR 550W CX SERIES™ CX-550 POWER SUPPLY
DeepCool AG400 Performance ARGB CPU Cooler
Extra Case Fans
2 x 120mm PCS Black Case Fan
2.5G ETHERNET PCI-EXPRESS CARD (10/100/1000M/2.5G) (1 x RJ45)
Price: £1,187.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-V/wYMtBpjypN/
I wouldn't buy that or any intel based build, the above is several generations out of date, your best bet is to go with an AMD build and maybe save a bit more cash so you've got a better budget to work with
sck451
Honestly if you have a gaming PC that's only a couple of years old, and if it was well designed in the first place, it might well bear upgrading rather than replacing. Was it a PC Specialist machine?
As to your build and budget, an AMD machine on the latest platform is achievable for £1400, though it wouldn't have everything I'd ideally want. You're looking at a 7600 CPU and either a 4060 or a 7600 XT as the graphics card. Those are very decent midrange options.
Jamc
A couple years was kind of an understatement i got it back in late 2016ish, ill definitely have a look at more AMD machines like you said thanks for the help
As a 'starter for ten' here's an AMD build keeping within your max budget of £1400, there'd be too many corners cut to get it to £1200...
CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE - better case for airflow
AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5) - faster, newer, more efficient CPU on latest (i.e. upgradable) platform
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) - latest (i.e. upgradable) platform. with built-in wifi
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) - sweet spot for AM5 CPUs
8GB NVIDIA GEFORCE RTX 4060 - HDMI, DP, LHR - current gen 1080p GPU, alternative is an AMD RX7600
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - much faster drive for Windows/apps/game launcher ONLY
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) - second fast drive for game installs
CORSAIR 750W RMe SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET - about the minimum we'd recommend for any level of upgradability & protection (latest ATX3/PCIe5 spec too)
DeepCool AK400 Performance CPU Cooler ZERO DARK
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £1,387.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/CKgn6zsc9H/
Ok, so what are you going to do with this old machine, if the answer is scrap it and its got W10 or above on it you could transfer the windows licence over to the new machine, which would knock about £100 off the build that @TonyCarter has put together above
sck451
Microsoft® Edge
In every detail the build I was thinking of!
Jamc
Thats a good idea actually i didnt even think of that cheers
Jamc
Microsoft® Edge
Absolute hero thank you im liking the look of that 🙏
sck451
With the extra cash from the Windows licence you can upgrade CPU and graphics card a bit and still be under £1400.
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
16GB AMD RADEON™ RX 7600 XT - HDMI, DP - DX® 12
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £1,368.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/aBuTM4n3x4/
