Hi, I will be upgrading to an ASUS TUF 4090 OG OC and my PSU is the Corsair RM1000e. Corsair make and sell an alternative to the adapter called a “600W PCle 5.0 12VHPWR Type-4 PSU Power Cable” they market it as “Connect PCle 5.0 GPUs (Nvidia 4000 series) up to 600W TDP”. I thought I could buy this cable and send it in with my PC for upgrade as an alternative to the adapter. My case is small, it’s an TD500 Mesh and if the adapter is stiff I worry there could be an issue getting the glass panel back on without causing strain on the socket. I take the panel on and off a lot to remove dust. I contacted customer service to ask if I bought the cable from Corsair could I send it in for use with the new 4090 as it would be more flexible but they said “unfortunately it is not possible to fit the GPU without the power cable as it could cause a fire and explode your GPU.” I assume he meant the adapter when he said cable. I can’t see anyone online who has ever had a fire due to the corsair cable and the early melting issues seem to have been blamed on the adapter and poor socketing by individuals. My question is was the customer service guy right? That cable is labelled as “best seller” on the Corsair website. It’s also my understanding that the cable in question is now shipped with all new Corsair PSU’s for use with 40 series cards. I’m a bit confused and just thought someone might be able to help,
Many thanks in advance
