Found a very strange bug that happens on my new 7800XT.
In Chrome/Edge I have noticed that when you hover over a text field (and the cursor changes) it also goes white, this is a problem because on a white background the cursor should be black, like it usually is.
Issue not present on Nvidia GPU.
I have switched to Firefox in the meantime but this bug is very persistent (there is documentation dating back to 2022 online).
Can any of you guys with a new RX GPU reproduce the error? Just open a tab in Edge, ensure you have the default mouse icons enabled (switching to the beam_r icon is a common "fix"), and make sure you are on Windows 11, with the latest updates.
Thank you all so much for reading! I appreciate any support.
PCS PRISM TG BLACK ARGB MID TOWER CASE
Promotional Item
AMD Ryzen 7 7600X Eight Core CPU (4.5GHz-5.4GHz/40MB CACHE/AM5)
ASUS® PRIME B650-PLUS (AM5, DDR5, PCIe 4.0)
32GB Corsair VENGEANCE DDR5 5200MHz (2 x 16GB)
16GB ASUS TUF GAMING RADEON™ RX 7800 XT OC - HDMI, 3 x DP - DX®12
Graphics Card Support Bracket
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
CORSAIR 750W CX SERIES™ CX-750 POWER SUPPLY
PCS FrostFlow 150 Series High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Welcome Book
PCSpecialist Welcome Book
Logo Branding
Promotional Item
Welcome Book
Logo Branding
