CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE - WHITE
Promotional Item
GIGABYTE B650 AORUS ELITE AX (AM5, DDR5, PCIe 4.0, Wi-Fi 6E)
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
Graphics Card Support Bracket
2TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
2nd M.2 SSD Drive
CORSAIR iCUE H150i ELITE CAPELLIX XT RGB High Performance CPU Cooler
Extra Case Fans
5 x Corsair ICUE LINK QX120 RGB PWM Fan + Controller Kit
If seen some conflicted information regarding how many case fans the 5000D Airflow case comes with so ive added the set of 5 ICUE Link fans to the build, would this work or cause any issues? Appreciate the help!!
Promotional Item
2nd M.2 SSD Drive
Extra Case Fans
