CPU Fan
BrandonPCS
I've Got A Vortex G70 And Would Like To Replace The CPU Fan But I Cant Find Anywhere That Sells Them And I'm Not 100% Sure What The Fan Is Called
If You Could Help I Would Be Grateful Thanks
Just the fan, or the whole CPU cooler (the block/fins/fan)?
If you could post your config from your order page, we could suggest a modern/good replacement that meets your needs (e.g. an i3/i5/3600/5600/7600 CPU would be fine with a Deepcool AK400 or AK620, but a later gen i7/i9 would need a 360mm AIO cooler).
BrandonPCS
Thats The Fan And No Not The Block Just The Fan Part That Has A PC Specialist Logo On It
