It's not 2-3 though, previously it was only at 100 because it was thermal throttling, would have been well over that if the chip wasn't lowering frequency and voltage to compensate. So the improvement could be significant.So, yes there is a slight difference but 2-3ºC but if you say its important I believe in you xD
Still not clear if you ordered with windows or installed your own copy? We don't know if PCS configured your operating system or if you set it up yourself? If you ordered without windows, it will have come with a test windows, but it's not configured so won't work properly.And no, I havent reinstalled windows even though I gave them permission to do it.
Again, you're simply delaying what you're going to have to learn to manage if you're owning a custom laptop. Can't stress this enough. You're never going to get proper performance if you're not willing to learn how to maintain the system.Meanwhile, I will remain the new thermal for some months now but then go to a laptop store to see if they can put the kyro sheet
Without knowing who setup windows it's impossible to know what this may be.Something that might be important that I havent referred is that my drivers from Intel Driver & Support dont work...I search for new drivers and it gives me error
