MarkusDraconis
Hi all, apologies for bumping, but is this still the best option. It's been almost a year since I last asked, and obviously things can change: Budget is £2500 inc. monitor.
CORSAIR 4000D RGB AIRFLOW TEMPERED GLASS GAMING CASE - much better case for thermals & quality
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) - the fastest gaming CPU at the moment, and uses much less power than the 13th gen i7/i9, also has years of upgrade options
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s) - higher quality board than the Primes
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) - much faster RAM, and will perform much better with it (as much as 10% more performance than 4800MHz)
16GB AMD RADEON™ RX 7900 GRE - HDMI, DP - DX® 12 - broadly equivalent to the 4070Ti, but cheaper and has more VRAM (there’s also the option of saving £100 and going for the 6800XT)
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - fast boot/app drive, as you surmised
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) - not quite as fast, but still great for games storage
CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET - gives some headroom for a CPU or GPU upgrade in a few years if you move to 4K
CORSAIR iCUE H100i ELITE CAPELLIX XT RGB High Performance CPU Cooler - decent 240mm (2x120mm fans) cooler for this CPU, you’d need a 360mm (3x120mm) min for the equivalent Intel CPUs
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £2,052.00 inc. VAT
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/5gzzaAVWyP/
Microsoft® Edge
