I would. Use ddu to uninstall the current driver, then install the latest direct from nvidia again.I never have this kind of installation. Nvdia Geforce experience download the lastest driver and install it automatically alone.
Should i try to remove geforce experience and do a clean install ?
In future when updating gpu drivers from GeForce experience, always select a custom install and a clean installation as above.
![www.guru3d.com](https://www.guru3d.com/data/publish/173/b0d2c6296adcaa52d672c4f2147d217f10bdec/2024_01_15_09_23_14_guru3d.webp)
Display Driver Uninstaller (DDU) download version 18.0.7.7
Download Display Driver Uninstaller (DDU) - Remove AMD/NVIDIA/INTEL Graphics Drivers Cleanly - DDU is a driver removal utility that helps you completely uninstall AMD/NVIDIA graphics card drivers and packages from your system, leaving no leftovers behind, including registry keys, folders, files...
![www.guru3d.com](https://www.guru3d.com/data/themes/frontend/Guru3D/images/favicon_64x64.png)
