You shouldn't need to run it as admin, that may explain why it's giving that error as it's trying to extract it to the hidden admin user profile rather than yours.Cant install this. It downloads the chipset software application, doesn't download a folder containing setup file like from the ASUS website. Even when running the application as admin, it just gives the same network location error that I have been getting.
This is more and more becoming the case with modern installers, because the installers are no longer installing to c:\program files but instead the user profile where they don't require elevation, if you elevate it will instead install it on that elevated user profile
Teams is another one that does this. You have to run it as the user or it won't install to that user.
