Recoil 17 Liquid cooler bluetooth not identified.
Hello,
I've recently recieved my liquid cooler for my Recoil 17. I've paired it via bluetooth but then it goes offline , not connected. The light on the cooler is a blue blinking as if it's still looking to be paired. The cooler is the LCT22001.
I understand that I need to have it connected in order to see the liquid cooler settings under the Control Center.
I've tried removing the device and adding it again and it shows as connected for about 10 seconds and then goes not connected. As well I am missing the connect button in order to manually connect to it. Initially I tought it's a bluetooth issue or a Windows 11 issue. I checked the 3 dots to see if I can connect but I only have the option to remove device. ( Screenshot as attachment )
Would this be a cooler issue or a bluetooth issue ?
When I paired it initially I could only find the bluetooth from the cooler when the bluetooth device descovery was set to advanced.
Thank you in advance.
Chassis & DisplayRecoil Series: 17" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Processor (CPU)Intel® Core™ i9 24 Core Processor 13900HX (5.4GHz Turbo)
Memory (RAM)64GB Corsair 4800MHz SODIMM DDR5 (2 x 32GB)
Graphics CardNVIDIA® GeForce® RTX 4080 - 12.0GB GDDR6 Video RAM - DirectX® 12.1
Liquid Series® Laptop CoolingPCS Liquid Series® Laptop Cooler
1st M.2 SSD Drive1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
Partitions: 1000GB
2nd M.2 SSD Drive1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
Partitions: 1000GB
Memory Card ReaderIntegrated SD Memory Card Reader
AC Adaptor1 x 330W AC Adaptor
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
BatteryRecoil Series Integrated 99WH Lithium Ion Battery
Thermal PasteLIQUID METAL PERFORMANCE COOLING
Sound CardNahimic by SteelSeries 2 Channel HD Audio
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® KILLER™ Wi-Fi 6E AX1675i + BT 5.3
USB/Thunderbolt Options1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
Docking HubPCS DS110 USB-C Docking Hub: 3 x USB 3.0, 1 x HDMI, 1 x RJ45, 1 x TYPE-C PD
Keyboard LanguageRECOIL 17 SERIES RGB BACKLIT USA INTERNATIONAL KEYBOARD
Operating SystemWindows 11 Professional 64 Bit - inc. Single Licence
Operating System LanguageUS International/USA - US English Language
Windows Recovery MediaWindows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account
BrowserGoogle Chrome™
Notebook MouseINTEGRATED 2 BUTTON TOUCHPAD MOUSE
WebcamINTEGRATED 1MP HD WEBCAM
Warranty3 Year Standard Warranty (6 Month Collect & Return, 1 Year Parts, 3 Year Labour)
DeliveryTIMED DELIVERY TO UK MAINLAND - MON-FRI (BEFORE 2PM)
Build TimeFAST TRACK 3 WORKING DAY DISPATCH
Welcome BookPCSpecialist Welcome Book
would it be possible that the cooler is at fault ? I mean , I pair the cooler, it connects then disconnects without a possibility to connect again. and the light on it continues to blick blue as it's still searching to pair.
It could be the firmware needs updating on the cooler, probably best to call PCS.
