cossinsmatthew
Hoping to order this specification or similar within the next couple of days.
The aim was that the spec be a significant step up on my existing system (i7-3770, 1050ti 4gb, 32gb ram (4x8gb crucial), 1.5TB HDD). This obviously achieves that - I am purchasing new RAM as that way I can keep the old system operational and because my existing RAM is only DDR3 1600MHz. I'm aware 32GB may be overkill but I'm an Engineer that occasionally does some intensive stuff with MATLAB and the usage can exceed 16GB - plus I figure it provides headroom.
I want the system to be able to run current games at close to highest settings on 1080p, with headroom to upgrade to superior display resolutions in the future. It should also be VR-capable and should ideally last me a decade - obviously hard to predict but hopefully it would just about run a new game in 2034 and should be more than capable of handling games expected to release over the next few years at high settings (GTA6, ES6, etc.). And of course around this time I could switch individual parts as required - something I cannot currently easily do due to be confined by some proprietary connections etc.
Any obvious significant issues with the specification?
Or any minor tweaks people would make?
Current cost is approx £1350. If it can be made cheaper without significant performance reduction then that is great. Vice versa if it can have a significant performance increase at a similar price then also great. Absolute hard budget of £1500 but hoping for <£1400.
PCS PULSE MID TOWER CASE (PWM)
Promotional Item
Intel® Core™ i5 10-Core Processor i5-12600KF (Up to 4.9GHz) 20MB Cache
ASUS® PRIME B760M-K D4 (mATX, LGA1700, DDR4, PCIe 4.0)
16GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
CORSAIR 650W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
DeepCool AK400 Performance CPU Cooler ZERO DARK
Extra Case Fans
2 x 120mm PCS Black Case Fan
ONBOARD LAN PORT
ASUS PCE-AX1800 Wi-Fi 6 (1201Mbps/5GHz, 574Mbps/2.4GHz + Bluetooth 5.2)
Promotional Item
Extra Case Fans
ONBOARD LAN PORT
