cossinsmatthew
Currently looking at three options:
Option 1 (budget maxed out):
AMD Ryzen 5 7600X Six Core CPU (4.7GHz-5.3GHz/38MB CACHE/AM5)
16GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
Graphics Card Support Bracket
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
DeepCool AK400 Performance CPU Cooler ZERO DARK
ONBOARD 2.5Gbe LAN PORT
Price: £1,499.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/HYPnhMC8vc/
Option 2 (Saves 19 quid, gets me bluetooth, possibly better WiFi):
ASUS® PRIME B650-PLUS (AM5, DDR5, PCIe 4.0)
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Price: £1,480.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/8cajYjcxK4/
Option 3 (same mobo as option 2 but cut the wifi/bluetooth card - can exclusively use ethernet and get bluetooth via usb dongle (what I do now - saves a further 23 quid):
Price: £1,457.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/!fq9eubKYG/
Thoughts? Ultimately if its worth it I'll bite the bullet and get Option 1 but I don't want to throw money down the drain even 42 or 19 quid if there is no obvious benefit so basically it depends on whether the motherboard choice has serious issues in quality or something.
And if the recommendation is Option 1 - does Option 1 look alright?
