See my previous post...Fair enough - sorry to badger the point but if I opt for Pro P44 over P41+, what would the difference be noticeable in gaming or in daily browsing/use of non-intensive programs. Or is it just going to shave a few seconds off boot time?
Advice on PC Spec.
Currently looking at three options: Option 1 (budget maxed out): Case LIAN LI LANCOOL 215 GAMING CASE Processor (CPU) AMD Ryzen 5 7600X Six Core CPU (4.7GHz-5.3GHz/38MB CACHE/AM5) Motherboard ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) Memory (RAM) 32GB Corsair VENGEANCE...
But if you went from a 500MB/s SATA SSD to a 5000MB/s m.2. SSD (on an identical build) you would notice a snappier interface, apps loading quicker, websites rendering quicker, AV scans happening quicker, Windows updates and app updates taking less time.
It all adds up, but it depends what your used to and how annoyed you get waiting an couple of seconds for something you know should only take 5 seconds to launch (and then spend an hour going down a rabbit hole to find out what's wrong with your machine...or maybe that's just me).
