Appreciate any advice on this build I put together
EvilGrins
If I'm reading everything right that's what @SpyderTracks has done here
Yeah, I know. It's just that for a 1080p monitor which is what I currently am running, I was told it might be overkill. I just wondered if the same applied to a 1440p.
Edit: You're right, I misread the dimensions before... Sorry!
EvilGrins
So I think I've made up my mind and I'm going to go with this:
ASUS® ROG STRIX X670E-A GAMING WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
24GB AMD RADEON™ RX 7900 XTX - HDMI, DP - DX® 12
Graphics Card Support Bracket
2TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £2,860.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/7rQ2vVmx9K/
** If there's anything you guys would recommend to change, PLEASE let me know or forever hold your peace!
I hope I have your blessings PCS forums 🤞
